Hi, this is my Vista32/64 mod driver for SB live 4.1/5.1 cards series, enjoy¡¡
Sound Blaster Live series 4.1 - 5.1 vista 32/64 driver (based on sb x-fi driver)
This Driver have Full OpenAL support, Surround sound, Louder volume, audio console functional, Microsoft enhancements (These enhancements allow highly advanced Bass Management Control, Speaker Fill similar to CMSS, but MS sounds better, Room Correction and Loudness Equalization) and same XP´sound quality.
Eax work with Alchemy¡
1-Uninstall old driver
2-Run setup, if ask the driver not whql,install anyway the driver work just fine reboot
3-Install Audio Console reboot, this is important to surround sound work, if not install audio console the sound only pass through two front speakers
4-If you hear distortion sound, change speakers to 4 or 5.1 (preferably use audio console if show all white use windows mixer but leave audio console installed to surround sound work) ; or change sample rate option in panel control, 48000hz 16bit work for me, if you can´t hear any sound after install the driver or change speaker setting, only mute and unmute volume in windows mixer and this fix the problem.
5-The sounds in vista enviroment have only two channel, test multichannel sounds in games like Bioshock or Prey
Note: For multichannel sounds in windows vista environment, you have to enable Speaker Fill option in control panel - sound enhancements setting.
I test multichannel 4 and 5.1 sounds successfully in Bioshock demo.
Other info
Audio console work¡¡ EAX work in games¡, Winamp and EAX´s effect in audio console work too¡
For this,use Creative_Alchemy_Universal_1.00.04 or Creative_ALchemy_1.00.03 both Daneil_K mod.
Creative MediaSource Player/Organizer 5.10.38 work too¡
Winamp 5.5 work perfect with ALchemy Universal 1.00.04 for SB Live! / Audigy
have full support hardware acceleration and multi speakers, the sound is very good¡¡
Instruction for winamp and other players:
copy dsound.dll´s ALchemy directory to Winamp folder. enjoy¡
COPYRIGHT NOTICE: The included files are property of Creative Labs, Inc.
The files:
http://rapidshare.com/files/64356124/SBAX_2_12_0001_20.zip
Creative audio console - Install this to surround sound work
http://rapidshare.com/files/65598530/AudCon.zip
Other files like ALchemy and Vista gameport driver
Creative ALchemy Universal 1.00.04 for SB Live! / Audigy
http://forums.creative.com/creativelabs/board/message?board.id=Vista&message.id=18972
Gameport support pack for Vista gameport driver
http://forums.creative.com/creativelabs/board/message?board.id=Vista&message.id=13336
http://rapidshare.com/files/67342817/CMS5_5.10.38.exe
Read other sb live driver post:
http://forums.creative.com/creativelabs/board/message?board.id=Vista&message.id=23567
http://forums.creative.com/creativelabs/board/message?board.id=Vista&message.id=19194
http://forums.creative.com/creativelabs/board/message?board.id=Vista&message.id=22938
All Tested with SB Live Value Model: CT4830 and Windows Vista ultimate 32/64bits
Full System Setup:
ATHLON 64 X2 4400+ Core Brisbane
K9N NEO V1.0 bios v1.6
2Gb Dual Channel OCZ Platinum Rev.2 800mhz
WD WD1600AAJS 160Gb SATAII
DVD-RW LG GSA-H42N
Zogis Geforce 7950GT 512MB PCIE
Sound Blaster Live Value
ATV-TUNER-F Advantek
Thanks to Daniel_K, and all user to support sb live series¡¡¡¡¡¡
Sound Blaster Live for ever ¡¡¡¡¡¡¡¡¡¡
