Solved Realtek HD manager missing
Haryel
Hello guys, this is my last hope to make this work.
I'm using the realtek HD audio, when i plug my headphone or my speaker they work fine but i tried to mess with a microphone and i can't open the realtek manager, i can't even find it anywhere actually.
I'm using windows vista home premium 32bit. I tried the new drivers, tried uninstalling and everything else. Is there something that i'm missing here?
I can't seem to make the mic work w/o the manager apparently. On the device manager the Realtek high def audio shows this version 6.0.6000.16386.
I tried download the 2.31 on the realtek website, to no avail.
Any help would be really appreaciated, probably loved.
Thanks in advance.
Hello Haryel, and welcome to Vista Forums.
That image shows that you do not have the Realtek HD driver installed. Try installing it only one more time and restart the computer to see if the Realtek HD Manager will then show in the Control Panel (classic view).
Thanks in advance.
G'Day Haryel,
First of all, welcome to Vista Forums, and may you find the experience a rewarding and happy one.
I was forever having problems 'getting it right' until I got some good advice and assistance from Dwarf and Brink, a couple of the great guys here. Do a bit of reading and have a look at this thread, and specifically from post #721(permalink) through to #737, just to see how my own problems were fixed;
http://www.vistax64.com/sound-audio/64250-latest-realtek-hd-audio-driver-version.html
You will find that I make reference to a Tutorial by Dwarf. That "Device Manager - Install Device" Tutorial is here;
http://www.vistax64.com/tutorials/193584-device-manager-install-driver.html
I hope that this helps you get your problem sorted, and never forget that there is always someone around, ready and willing to help.:D Just one bit of advice though, it helps if you complete all the information in your 'My System Specs'
Dang! Speak of the Devil, I've just seen that Brink has beaten me to the reply.....never mind, you're in good and capable hands, and I'll put this up as well.
Cheers, and all the best:party:
EDIT
This is where your System Specs are useful. Some PC/Laptop Makers have the Realtek HD Audio Drivers and Manager, assume their identity. To explain, these are my 'Realtek' Details in Control Panel [Classic View] and in Audio Manager;
    nVidia GeForce Go 7300, 128MB
    1280x800x60Hertz [max.]
I followed the tutorials faithfully and reinstalled everything, still no manager sadly.
I appreciate the help here guys, but this realtek stuff it's getting complicated.
EDIT: By the way, when i try to update the driver manually like the tutorial, it says that its already up to date.
This is my Mobo, got the info from the everest program: Motherboard ID 63-0100-001131-00101111-021808-Lakeport$P17G_P17GRELEASE
Motherboard Chipset Intel Lakeport-G i945G
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Hi Haryel,
It's the LAN (network) driver that is Realtek. Have you solved your sound problem?
    Gigabyte IF233
I tried the PCCHIPS sound driver it gives me an error tho, it says "We can' find the HD audio drive"
EDIT: Actually nevermind. The other link Dwarf provided me made everything install properly. You're the man Dwarf.
Thanks to everyone that replied!
I was forever having problems 'getting it right' until I got some good advice and assistance from Dwarf and Brink, a couple of the great guys here..... I make reference to a Tutorial by Dwarf. I hope that this helps you get your problem sorted, and never forget that there is always someone around, ready and willing to help.:D
Dang! Speak of the Devil, I've just seen that Brink has beaten me to the reply.....never mind, you're in good and capable hands.....
.........:roflmao:......and Double-Dang! I knew it! I knew it!! My waters told me that the second Devil would come to the party!! I am so glad that you got your issue resolved. See you around again, sometime.......:party::party:
Hi Haryel,
I'm pleased that you have managed to install the driver. Is your microphone working now?
    Gigabyte IF233
If you are ever uncertain about a driver, or have a question mark for the driver, you may want to do the following.
Control panel. System. Device Manager. Right click on driver in question. Left click properties. Details. Provides vendor and device id (e.g., alphanumeric string like this PCI\VEN_1217&DEV_7130&SUBSYS_012F1025&REV_01\4&6B16D5B&0&33F0). Take this info and go to PCI Vendor and Device Lists
You can do a vendor search or a device search.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Creative Sound Blaster X-Fi Titanium
Microsoft Windows 7 64-bit, Windows 7 32-bit, Windows Vista 64-bit with Service Pack 1 (SP1), Windows Vista 32-bit with SP1, Windows XP Professional x64 Edition, Windows XP Service Pack 3 (SP3), Windows XP Media Center Edition (MCE) 2005 or Windows XP MCE 2004
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Control Panel>Device Manager>[RC] Realtek HD Audio>Properties>Details>Under Property [V] drop down menu, I found it listed under Parent.....Correct?
PCI\VEN_8086&DEV_27D8&SUBSYS_00901025&REV_02\3&33fd14ca&0&D8
No mention of Windows Vista 32-bit SP2?
Correct, Sassofalco. I omitted that. It really does come in pretty handy.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
