Headphones are not working
i_say
Okay:
About 2 days ago i installed SP1. After installing i noticed my headphones not working so i checked them on my mp3 player - everything was alright. Then i thought it could be the jack port, so i tried to clean it - no results. My dad was gone so i had to handle myself. Googled and found this forum. Then i thought it could be drivers, because many people are encoutering this problem. I downloaded Realtek drivers and nothing!
It is possible that i don't know what drivers i should download.
And motherboard is Gigabyte a micro model, don't remember the numbers.
Help would be appreciated :D
Realtek would be your *soundcard* drivers - do you headphones require separate drivers? If so download *those* and reinstall those as well.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
I don't think my headphones require any drivers, because before SP1 they didn't. Also, my motherboard is my sound card (i don't have a separate sound c.), but i don't know if this is important.
that is important - uninstall the current drivers for your motherboard sound in device manager, and then reboot and reinstall the latest version.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
How can i know what drivers are for my motherboard? I installed the newest realtek drivers which i found here, but they don't seem to solve the problem :/
Go into device manager and see if your HD audio cannot find the right drivers, or if it can. If it can, then make sure you set up the Realtek devices afterward (there should be a new icon in your system tray).
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Well, I have a polish version of Vista, so i'm not very sure if i'm doing it right.
START > Control Panel > Device manager >
and here i have (would put a screenshot if knew how)from the top:
+graphic cards;
+network cards;
+keyboards;
+computer;
+controllers of sound, video and games;
a few thing i can't translate;
+Monitor;
+mouse and other pointing devices;
+ports (COM and LPT); procesors;
+disc drives;
+disc drives CD-ROM/DVD;
+devices of HID;
+system devices
in controllers of sound, video and games i have Realtek High Definition Audio which says is working properly
in system devices i have something which is: Controller compatible with High Definition standard which is also working properly
