You should upgrade or use an
alternative browser .
Graphics problem help gtx 275
My gtx 275 on windows experience index shows as graphics 5.9 and gaming graphics 5.8 WTF ARGGH I just bought this card and before i had a 9800gt which score 5.9 in both whatt? Please help!
iv refreshed the score twice and i think u guys know which card is better a 9800gt or a gtx 275?
Iv got the new beta 195.39 nvidia drivers!
Intel Pentium Dual Core E5200 Overclocked @ 2.90
ASUStek
OCZ DDR2 PC2-6400 Vista Performance Gold 4GB Dual Channel
ASUStek ENGTX275 PCI-E x 1
19inch benq
1400x900
400 gb
700 Watt artic power
Artic cooler
4.70 mb/s download, 0.37 mb/s upload
Thats weird when i swapped graphics drivers to the certificied version is went to 5.9
what does this mean?
ASUStek
19inch benq
1400x900
400 gb
Artic cooler
it just means nvidia is the one with drivers issues now
AMD Athlon X2 5000+ @ 2.6Ghz
Acer Micro-ATX Motherboard
ATI HD3870 with 512mb GDDR4
Realtek HD 7.1 Onboard Sound
22" Acer X223 Widescreen
1680 X 1050
500gb Seagate SATA II
ULTRA X3 600 Watt Modular
Microsoft Sidewinder X5
Microsoft Sidewinder X6
6 Mbs Down 1 Mbs Up
AVerMedia 1500MCE TV Tuner
I Tunes hates Me
it means nothing stop worrying about those bloody experiance index scores or theres gonna be a fight...........
the 195.39 drivers are dogs anyway the first release caused all sorts of issues NV took em down and replaced them with a new version and their just as bad
fyi all the 19 series drivers are buggy there is no way to force AA or AF through the control panel , gamma correct AA and transparency AA doesnt work either the last set of working drivers was 186.18 , so if you want a proper set of bug free drivers i suggest you roll back to them :P After properly uninstalling the old ones obviously , do you know how to properly uninstall GPU drivers?
If not download and install this ..............
http://downloads.guru3d.com/Guru3D---Driver-Sweeper-%28Setup%29_d1655.html .......... instructions
How to use ?
Guru3D - Driver Sweeper is very easy to use. You only have to select the drivers you want to clean.
The best way to clean drivers is to first uninstall the drivers using the official uninstallers, reboot in Safe Mode and run Guru3D - Driver Sweeper. However, rebooting and not going into Safe Mode also works, but can cause some files not to be cleaned.
XFX 780i
4GB OCZ PC2-8500C5 DDR2
Gainward GTX260/216 SLI
Creative X-FI Xtreme Gamer
Dell UltraSharp 2209WA 22"
OCZ Modstream 700w
Titan Fenir
Logitech G5 Gamer
Razer Reclusa
8mb
wait..... archie! you just admitted that all the 19 series or drivers are buggy..... i thought that was why you switched from ati
what happened? haha
1680 X 1050
6 Mbs Down 1 Mbs Up
Thanks ill do that!
I do know about driver sweeper great program!
ASUStek
19inch benq
1400x900
400 gb
Artic cooler
The experience score was a base reading when vista came out, it only went to a certain rating and was unreliable at best. if you play music or video while you run your score, you should find your results differ also. This is something that each pc has different.
Self built
Q9550 overclocked to 3.93Ghz
XFX 790i Ultra SLI
(8Gb) - 2x2GB DDR3 Corsair Dominator Ram 1600Mhz + 2x2GB DDR3 OCZ 1600Mhz
Asus GTX 280 + Gigabyte GTX 280 (SLI)
Creative Soundblaster Fatality1 TY ultra Titanium
3x24" BenQ, 22"Viewsonic
1920x1200, 1920x1080, 1920x1080, 1680x1050
2x 750Gb Samsung Spinpoint Raid 1 array
3x 1TB Western Digital
Antec 1000W
Gigabyte low end full-tower
CoolerMaster V10 for CPU 7 120mm fans
Logitech G9, G7
Logitech Dinovo edge, dinovo mini
24mb/s D/L 15mb/s upload - Telstra
7 Fans - 3 fans integrated 4x case cut to fit and integrated into the case.
Ok i did that are you sure that will help performance? Everything seems alot darker as well now im on the 186 driver!
ASUStek
19inch benq
1400x900
400 gb
Artic cooler
ASUStek
19inch benq
1400x900
400 gb
Artic cooler
I Tunes hates Me
no mate it wont help yuor performance at all
it wont be any differant to the newer drivers , if you dont want to use any of the enhancemants in the nvidia control panel such as Gamma correct AA or Trans AA and you dont want to force Antialaising via the control panel then by all means use the newer drivers
i gave you the option of those drivers as they are the last set of drivers that had a bug free control panel , even the game profiles dont work properly in the 19 series
try and make sure you run driver sweeper in safemode everytime you reinstall new drivers , it gets rid of any old files that may be hanging around that could possibly cause instability
XFX 780i
OCZ Modstream 700w
Titan Fenir
Logitech G5 Gamer
Razer Reclusa
8mb
Cheers archie
ASUStek
19inch benq
1400x900
400 gb
Artic cooler
