I need help installing a XFX Geforce 8500 GT. When i try to install the drivers it says the nvidia drivers are not compatible with the current hardware. What should i do?
Try rolling back the graphics card driver to that which came with Vista (see the following tutorial). You will need to restart with each roll back. When you have done this, restart your PC and log into an account with administrative credentials. You should then be able to download and install the driver (link given below).
Dwarf
ViewSonic VA1912w Widescreen
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
