Cristian13
Hello, I am having really bad BSOD issues on my computer. My computer is a Windows Vista Home Premium Inspiron x64 bit. Okay I know my CMOS battery is used up, has about 5 years of the battery so I just bought a Rayovac CR 2032 3 Volt Lithium Battery from Walmart. Now im just going to order a Anti Static Wrist Band and I will replace the battery. But i have no idea whats the problem. My computer turns on and if im using it. It will stay on for about 8 mins and than turn off. Sometimes going to a BSOD Blue screen. Reboots starts up again and turns off. Or sometimes my monitor goes to power save mode and turns off but my CPU is still running but the monitor is off. But so i inserted a Windows Vista Application Reinstall, but i clicked next and went to start up repair and found some errors but fixed it up, so theres no problem. Right now my computer is on and working right because im in Safe Mode & Networking but sometimes it turns off. But surprisingly it hasn't turned off right now. But im having some serious BSOD problems, I need help because I don't know whats the problem I'm confused and I need help immediately. I also followed the instructions and i attached the SF Diagnostic .zip file with all my information noted in, as I ran the program successfully.
Thanks !
Thanks !
- Dell Inc.
- 4096 MB (4 x 1024 DDR2-SDRAM )
- ATI Radeon HD 3200 Graphics
- Dell Computer DELL S1909WX - 19 inches
