Security centre not starting
had enuf
I cannot get my security centre to start. I have tried to make it run automatically but it changes back to disable straight away. I also cannot open any internet explorer pages, I am using safari at the moment. I am unable to run malwarebytes as my laptop does not seem to allow it. I also cannot access any microsoft sites through safari.
Any help would be appreciated.
Welcome
Sounds like a typical case of malware. Try to run mawarebytes in safe mode.
Run your anti virus, in safe mode if necessary, too.
If you cannot get those to work, try to use eset online scanner. It uses a different method to scan and should work.
As a last resort, go back a week before the problem began, with System Restore
had enuf,
If you wish to have some additional help, let's find out what is going on with your system...
Please download Tlcharger RogueKiller (Site Officiel)
When you get to the website, go to where it says:
(Download link) Lien de téléchargement:
Select the 32-bit version. (without x64)
Click the dark-blue button to download.
Save to the Desktop
Close all windows and browsers
Right-click the downloaded file and select: Run as Administrator
Press: SCAN
A report opens on the Desktop: RKreport.txt
Please provide the RKreport.txt (Mode: Scan) in your reply.
Next, please use the Farbar Service Scanner Download
Save to the Desktop
  • Make sure the following options are checked:
    • Internet Services
    • Windows Firewall
    • System Restore
    • Security Center
    • Windows Update
    • Windows Defender
  • Press: Scan
  • FSS creates a log, FSS.txt, on the Desktop.
Please provide the FSS.txt in your reply.
