Solved Avast Scan Slow. My System?
VFN
Avast Quick Scan is taking me about 25 minutes or so and I think that's slow. The scan stays at the 9% mark for several minutes and during some of that time my mouse becomes laggy, the Avast window tabs become unresponsive, my Start button becomes terribly laggy, so my whole system seems to slow terribly. In terms of sluggishness, I've noticed for a while that when I increase a video to full screen, I can see an Adobe taskbar tab emerge before the screen is full. My internet seems sluggish at times as well. (My speedtests are okay but my Ping Tests have declined from where they were sometime back.) At any rate, is there a way to check my system to see if Avast is not the problem, that it's my system?
Thanks as always
    Vista Home Premium x64
    Dell Inspiron 546
    Sempron LE-1300
    2GB DDR SDRAM 800MHZ-2X1GB DIM M
    Integrated ATI Radeon HD3200
    VIA High Definition Audio
    Samsung 32" HDTV
    1366 x 768
    320GB NCQ Serial ATA (7200 RPM) w/ 16MB DataBurst Cache
Yeah, I thought about that.
Why do you have Avast if you prefer Essentials?
    Dell Inspiron 546
    Sempron LE-1300
    Samsung 32" HDTV
    1366 x 768
LOL
Change have to had.
OKay. Will check MSE out.
Thanks.
    Dell Inspiron 546
    Sempron LE-1300
    Samsung 32" HDTV
    1366 x 768
You are welcome, let us know how you make out.
