Solved Malwarebytes Won't Load
VFN
Just downloaded latest update 1600.0.1800 and Malwarebytes won't load now. Anyone having this problem?
Thanks
    Vista Home Premium x64
    Dell Inspiron 546
    Sempron LE-1300
    2GB DDR SDRAM 800MHZ-2X1GB DIM M
    Integrated ATI Radeon HD3200
    VIA High Definition Audio
    Samsung 32" HDTV
    1366 x 768
    320GB NCQ Serial ATA (7200 RPM) w/ 16MB DataBurst Cache
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Extra info for OP
FAQ - Malwarebytes' Anti-Malware won't run or failed to resolve my issues
    Dell Studio XPS 435T 12gig's ram, 2000 gig's HD
The Malwarebytes forum ssem to have several people who've experienced problems with the new update. Via their direction, I clean installed and now the new version is working. What does that tell us? That the update install glitched, that there's something corrupt in it or there's an infection in my PC which is strongly suggested by the links you so kindly posted?
Found this on their forum: Unfortunately, the real issue has to do with the uninstaller for 1.51.2 sometimes leaving files in place after uninstalling it during the upgrade install, that's the reason that most of these issues are fixed by running mbam-clean.exe, rebooting, and then installing version 1.60 fresh
Seems Malwarebytes may have problems with updating at times, so I'm marking this as solved. Will read replies if anyone thinks it's something other.
Thanks.
    Dell Inspiron 546
    Sempron LE-1300
    Samsung 32" HDTV
    1366 x 768
Oh, mine works fine. sorry you experienced issues. The clean install works good. I thought you had a virus stopping it from installing. Did not really have full picture of your issue. Glad you are loaded up with current version . Excellent program.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Just to clarify, I updated and it said it was successful but when I tried to open the program it wouldn't open. Should've used the word "open" instead of "load."
    Dell Inspiron 546
    Sempron LE-1300
    Samsung 32" HDTV
    1366 x 768
Just to be clear here. you have Latest Mbam and latest update, but the issue is that it will not open up ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
That was my issue: I updated Malewarbytes which installed the new version but the new version wouldn't open. I would get a close Vista "close program" or some similar message when I tried to open it. I clean installed and now it works.
    Dell Inspiron 546
    Sempron LE-1300
    Samsung 32" HDTV
    1366 x 768
Oh, k, just wanted to make sure. Your posting was not clear. Great news.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Thanks for your help and attentiveness.
    Dell Inspiron 546
    Sempron LE-1300
    Samsung 32" HDTV
    1366 x 768
Your welcome, keep those above links for if you ever have issues fighting malware. Bookmark them for future reference and happy surfing as well as Happy New Year . Stay safe !!!
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
