Hi All you fellow 'Forumers',
Another day, another problem, I'm certainly learning the hard way.
Last night in the forum I had problems with NvCpl.Dll Errors, missing Entry et.
Great advice from Richc,thanks, but still unresolved totally. But that will do for later in the day.
I decided to further check items for out of date drivers, software etc., and went on the Asus support site to check on motherboard 'bits & pieces'.
Downloaded the Asus support Wizard, and got security alert 'Active X' is a problem.
AKAMAI DOWNLOAD MANAGER was the instigator of this.
Tried to find it, but where the chips its gone I don't know!
Looked through all my files I can think of. Been to download Program Files, no luck,
Has anyone come across this before? Would appreciate guidance in this daily toil of 'Computer Education'. It's Sunday I shouldn't have Homework!! Thank's in advance.
- Hewlett-Packard SR5019UK
- AMD Athlon 64 processor 3800 + 2.40GHz
- M2N68-LA (Narra)
- 2.50GB
- nVidia GeForce
- Realtec ALC888 Audio
- 17" LCD Monitor
- 160 Gb Usable Hard Drive
- Other Info
- HP G56 Laptop Win 7 64bit. 4Gb Ram DDR2's. Hitachi 450Gb Hard Drive. Pentium(R) Duel-Core CPU.
