You should upgrade or use an
alternative browser .
problem with malwarebyte's anti malware software
hi guys I'm having problems with malwarebyte software
from this site
Malwarebytes
I had this software before and it was running good until I updated the DB version
to 5046.
when I ran full scan it stops at file location where my voice chatting program for gaming. It stays at that location and never go further than before update.
I don't know what the problem is.. do you guys think that malwarebyte is not compatible with foreign softwares? its a korean software.
if you guys think it is then will you guys recommend me other anti virus scanning softwares?
46.8 KB
HP
Intel(R) Core(TM)2 Duo CPU P7550 @ 2.26 GHz 2.27GHz
nVidia GeForce GT 130m with 1024mb ddr2
1366 by 768 pixels
Microsoft Security Essentials is good and used by many including myself.
I like the sound of being protected! So can the Microsoft security essentials be run with something like Norton 360 & Spybot or is there a conflict services?
HP-Pavilion m9280.uk-a
ASUS NVIDIA Geforce GTS450
HP w2408 24.0" (Dual monitor)
1920 * 1200, 1920 * 1200
BluRay & DVD Weiters
40 Meg
Cannot run Norton with MSE
MSE and malwarebytes and windows firewall is more than enough.
Ok,
Thank you for the heads up on that.
Do you recommend anything in addition to what I already have?
40 Meg
[MSE, Malwarebytes and the Windows Fire Wall
This would be all you need, many here use it. I use it and am 100% satisfied.
Is all that 100% free & is the fire wall easy to control?
My experiance of the of the "Auto" configuration MS firewall is not good as it requires too much manual intervention to get "Stuff" working.
Is this just me or the system? Afterall it was XP and I 've stuck with Norton ever since then.
40 Meg
Eveything is free and made just for windows. The firewall is easy to set up. You can use that firewall or another free one. I suggest you use the Windows Firewall and come back here for help if you cannot set it up, but its real easy.
Brill,
that might have just save me some £45 as my renewal is due in
42 KB
40 Meg
There is no need to pay. I would not mislead you.
So,
What you are saying is ditch both & go with the three? All for free!
40 Meg
I do not want to put it that way. I am saying that I think the three that I suggested are just as good as what you have and its free. Mine are made just for Windows and works great at protecting your computer. I am saying that I have them on my computer.
Heres an Idea month before your subscription is up make a system restore point. Dump what you have and put in mine. If you like it dont pay for the others; dont like it use system restore to put yours back. Thats a win win situation
and
Thanks so much for the rep.
Intel(R) Core(TM)2 Quad CPU
INTEL/D975XBX2
ATI Radeon HD 2600 Pro
Samsung SyncMaster 914v
1280 x 1024
2/500GB each ... ST3500630AS ATA Device.
One is not connected
Rocketfish 700 W
G.Skill Gigabyte Chassis
Microsoft PS/2 Mouse
DSL
ATI HDMI Audio
