Enable lua problem
susanathm
I REBOOT THE COMPUTER AFTER STEP 8 OF THE FOLLOWING STEPS, AND I CANNOT LOGIN TO MY ADMIN ACCOUNT (I ONLY GOT ONE ACCOUNT) AND I AM PRETTY SURE WHAT MY PASSWORD IS, BUT I JUST CAN'T LOGIN TO IT, HELP..... I CREATED ONE PROBLEM AFTER ANOTHER...
THEN I FOUND A SOLUTION TO MY PROBLEM OF MY NOTEBOOK, ON THE WEB AS FOLLOWS AND I FOLLOWED IT,
Step 1: Go to safe mode and run CMD (Command Prompt);
step 2: type exactly "Net user administrator/active:yes";
step 3: type exactly "Net stop Profsvc";
step 4: alt+control+Del => newtask => type "explorer";
step 5: go to start and the Run and type "msconfig" then go to tools tab and launch the Disable UAC (User Account Control);
step 6: then launch Registry Editor (Or go to run and type regedit);
step 7: go to this direction "HKey_Local_Machine\Software\Mictosoft\Windows\CurrentVersion\Policies\system. ";
step 8: Find "Enable LUA" and locate the value of "0";
step 9: Your security tap of C drive will be available;
Note : do not forget to back up your registry or change back the value.
Hello,
First, we will try to change it back, and if that does not work, we may be forced to crack the password, though as a last resort.
Follow Method 1 (From a Download) here (unless you have a Vista DVD, then skip this step): http://www.vistax64.com/tutorials/141820-create-recovery-disc.html
Boot to the Command Prompt, see here: How to use the Command Prompt in the Vista Windows Recovery Environment
Now type C:\Windows\regedit.exe and press enter. Alternative command: cd C:\Windows then regedit.exe
File > Load Hive > C:\Windows\System32\config\SOFTWARE
Change back registry key change
File > Unload Hive
Reboot, and test.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Thanks very much for replying me, I can open, I can only c:\windows\system32\regedit, is this ok? c:\windows\regedit not work, no reaction after I typed.
Anyway, I did the rest, up to File > Load Hive > C:\Windows\System32\config\SOFTWARE
It pops up a window key name, I typed ENABLE LUA, then OK
I put the cursor on software, then Unload hive, it says, cannot unload software, access denied.
What to do next? help...
somehow, i tried again, and and now able to change enable lua to 1.
I remembered, (sorry I didn't mention earlier) on the instruction list i posted earlier, instead of
type "Net user administrator/active:yes";
I typed "Net user user 1abc/active:yes" note: 1abc is my password, and the admin login name is user. In this case, have i changed my password. Please advise...
