help with Vista Home Basic oem system failure corrupt system file.
eliteboy
A few days ago, after a windows automatic update, my computer is no longer able to boot. It returns this message: ...\Windows\System32\Drivers\zeqpju.sys system file missing or corrupt. I have tried to do a recovery several times with no luck, I've tried everything I know to do in safemode and dos, I've even tried every method possible on the spotmau cd, but I still get the same bs!
Any ideas would be greatly appreciated. Also, I cannot locate any information concerning the zeqpju.sys file...do you know where I can get this file, so that I can try to replace the matching corrupt file on my system?
Thanks...:confused:
    Q2Designs Model No:MS-10342B
    Dual Genuine Intel(R) T2400 @ 1.83GHz, 1826Mhz, 2 Core(s)
    MICRO-STAR Model #: MS-10342B
    2GB
    Intel GMA 950
    Realtek ALC882D
    Internal HDD 60GB External HDD 250GB
    15Mbps
Hello eliteboy,
I have had a look for the zeqpju.sys file and cant find any info on it anywhere. Are you sure that is how it is spelt ?.
There are a couple of things to try.
First open a command prompt as administrator and type sfc/scannow press enter and let it scan, if errors are found you will have to scan again until clean.
If that does not work, try a startup repair with the Vista disk.
Follow this link to a tutorial.
http://www.vistax64.com/tutorials/91467-startup-repair.html
If you don't have a disk, go here.
How to Make a Windows Vista Repair Disk If You Don’t Have One - How-To Geek
Hope this helps, good luck and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Your link goes to my post!
    2GB
    Intel GMA 950
    Realtek ALC882D
    15Mbps
