BSoD 0x0000007f (PLEASE HELP)
nbkp
Every half an hour on my computer I get the most annoying thing ever... BSOD!!!! I don't have much to say about it.... Much appreciated.
Specs:
Windows Vista Ultimate (32bit)
AMD Athlon 64 3800+ 2.41GHz~
nVidia 8600GT 1GB DDR2
4x 1GB DDR2 RAM 4400MHz
Image:
Can you please browse to the:
"C:\Windows\Minidump"
folder, zip up the contents (using 7-Zip if you do not know how) and upload the zip archive. Then we will help you.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
You have two different BSODs here:
UNEXPECTED_KERNEL_MODE_TRAP
STOP: 0x1000007f
Also:
STOP: 0x00000116
Referenced Drivers:
dxgkrnl.sys
ntkrnlpa.exe
nvlddmkm.sys
This BSOD is often caused by drivers, overheating, faulty hardware etc. The most important thing to do is to update all of your drivers. Here is a list of thing to try:
  • Update all of the drivers you can.
  • Run Memtest86+ or another memory testing tool that came with your computer.
  • Make sure all windows updates and service packs are installed.
  • See if these BSODs occur in Safe Mode and report back.
  • See if there are any errors showing in Device Manager.
This problem may be caused by overheating, so can you please download GPU-Z and SpeedFan and write down/screenshot the temperatures of your cores/graphics card/hard disk.
GPU-Z
SpeedFan
The referenced drivers may point to your graphics card drivers, and so one of the first things to try would be updated graphics card drivers.
You also have some very outdated drivers (2002, 2005, 2006, 2007, lost time stamp)
These should also be investigated and updated.
Good luck,
Richard
    Dell XPS 420
    Stock Dell 0TP406
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
