I installed ZoneAlarm Firewall and after that my PC stopped responding. I`m using my PC in safe mode. And when I turn it on on normal mode, my PC loads and then it stops responding. I can`t use System Restore because System Protection is turned off. Please HELP!!!!!!!!!
- Acer Aspire M1641
- Intel Dual Core E2220 2.4GHZ
- 2GB DDR2
- ATI Sapphire Radeon HD 3450 256MB PCI-E 2.0
- Philips 192E WideScreen LCD Monitor 18.5`
- 1280x1024
- Seagate ST3250318AS, Western Digital WD3200AAJS-22L7A0
- 2048kbps downloading, 512kbps downloading
- Other Info
- Planning to Upgrade my PC...
