McAfee - Scan, I need help !
aikma
I am doing a McAfee scan right now. I find there is two items detected. They are quarantied at the moment. There is three options, Remove, Restore (fix infected file) or Send to McAfee to examine. It is called:
1)
Detection name: Artemis!98808CB47DF4
File: C:\Program Files\Hewlett-Packard\TouchSmart\Media\Kernel\DMP\CLAudSpa.ax
Process: C:\Windows\system32\msiexec.exe
Process description: Windows installer
2)
Detection name: Artemis!7D771BACDDD8
File: C:\Program Files\Hewlett-Packard\TouchSmart\Media\Kernel\DMP\clauts.ax
Are these files important ? What should I do, Remove, Restore (Repair ?) or McAfee examine files.
1)
2)
Hi and welcome
The two files if infected need to be removed no matter how important. from the location the ya located I dont suspect they are critical to anything in the OS
Repair if you can, remove if you cant
Good luck
ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
I had several artemis issues. I sent them to McAfee, they did nothing, I restored them, the artemis has multiplyed and finally I had no choice but to remove them. They were in the hP Touchsmart file ? I don't think it will affect anything.
