JMH
Banned
More -Most people sleep better at night knowing their PC is well equipped to thwart oncoming malware attacks. Out of paranoia some actually install multiple antivirus programs -- even though that's overly counterproductive.
Indeed, with everything that you do on your computer and the information that resides on it, the safety of your sensitive data should be top priority. That said, with a little experience you can traverse the World Wide Web in peace with minimal security on active patrol.
Many readers will probably say "no thanks" and slip out the back door, which is totally understandable. I will tell you flat out that most people are better off with some form of antivirus watching over their shoulder. But regardless of whether or not you keep one on guard, having safe browsing habits is essential to keeping your computer malware-free. To elaborate on that briefly, "safe browsing habits" means that those who spend their days on shady porn and warez sites need not apply. Recognizing the nefarious from innocuous is your greatest line of defense. Typically, malware gets onto a computer by being bundled with seemingly legitimate software, media, email attachments, and so on; so if something infects your system it's likely you've unknowingly let it mosey through the front door.
How I Keep Clean Without an Antivirus Guarding My System - TechSpot
- LAPTOP. HP Pavilion dv7-1005TX .
- IntelCore [email protected] x2
- 4.00 GB installed, max capacity 8 GB.
- Nvidia GeForce 9600M GT & 512MB DDR2 dedicated graphics mem.
- 17.0" diagonal WXGA + High definition brightview widescreen infinity display.
- 1440 x 900
- SPECS. Drive 1. 298.09 GB Fujitzu MHZ2320BH G2 ATA Device Drive 2. [ All as above.] CONFIG. C:\287.65 GB, D:\298.09 GB, E:\10.44 GB.
- Case
- Laptop / notebook.
- Cooling
- Stock.
- Synaptics PS/2 Port touch pad.
- IBM enhanced
- ADSL [ Too slow.]
- Other Info
- Webcam.
