You should upgrade or use an
alternative browser .
I need help badly please.
I keep getting the windows Malicious removal tool... i guess it comes with windows?
I ran many of my virus scans and they shows nothing.
this shows up System alert: virus Virtob.Win
it pops up randomly...... is there a way to remove it?
I am more than 100% i don't have viruses.
Toshiba A135-S2345
1 GB
140 GB
Hello Pinakfans,
Have you already run a full scan with the
Malicious Software Removal Tool to see if it can find anything, or possibly reset it if nothing is found?
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
Hell o pinakfans,
After you have followed Brink's advice -
1.Would you please provide all of your system specs [Just click on this link to do so.]
This helps to ensure all the pertinent information is listed & appears on every post you make.
It then better enables us to help you & saves valuable time, both yours & ours.
2. Please list all of the Security progs that you use.
3. Is UAC turned on?
4.Did your computer have a preinstalled Anti Virus prog?
IntelCore [email protected] x2
1440 x 900
SPECS.
Drive 1. 298.09 GB Fujitzu MHZ2320BH G2 ATA Device
Drive 2. [ All as above.]
CONFIG. C:\287.65 GB, D:\298.09 GB, E:\10.44 GB.
Laptop / notebook.
Stock.
IBM enhanced
ADSL [ Too slow.]
Webcam.
Could you perhaps post a screenshot of what MRT has captured?
Compaq
intel 965 chipset family
2 GB DDR 2 SD RAM @ 667 MHz
On board upto 358 MB RAM
15"
160 GB WDC
when it pops il screen shot it guys
Toshiba A135-S2345
1 GB
140 GB
I haven't had Malicious Software Removal Tool find 1 thing even with full scans in like a year +.Stuff like that I kick to the curb as useless after that long.
gateway
intel quad
8 gig
nvidia
realtek
19' widescreen
1440 x 900
581 gb
High speed Comcast cable
