Can any one please help me...
This is a really new problem that i have never come across . Here is what happened. I tried to use a USB to copy some files.
The USB contained folder.exe and foldername.exe virus. I removed the USB immeditely from my laptop.
From then started the problem.
Some unknown virus got into my system which was not identified by my etrust or norton virus scanner.
From then my computer started malfunctioning. In the start up screen it locks the keyboard mainly the numbers and space bar and automatically fills in the password box.
With difficulties if we boot into the desktop some programs like windows media player, internet explorer opens several times with out control and finally locks the system. I formatted the hard disk and newly created the partition.
Also reconstructed the bcd, boot files with windows recovery. Still no luck same virus same problem still there.
Tried to fix the problem with my system service engineer. But no luck. This is a great deal.
Would appreciate any help in solving this problem.
Note- When i tried to rebuild bcd with boot command to my suprise there was a number automatically generated near the oldbcd file when tried using the back up bcd.
Now that after formatting windows and loading new one none of my anti virus works
even my task manger screen dont show up... Please help
Thanks in advance
Thanks in advance
