How do I make wireless usb an exception with Avast Antivirus?
Cookie7898
Hello folks,
Everytime I plug in my USB wireless internet, Avast picks it up as malware, so I click ignore everytime. How do I set up an exception for it in Avast. I tried but couldn't find a file to click on for the exception.
Perhaps you should stop using Avast if it is giving false positives?
You need to use the Exclusion lists:
For the Standard Shield provider (on-access scanning):
Left click the 'a' blue icon, click on the provider icon at left and then Customize.
Go to Advanced tab and click on Add button...
For the other providers (on-demand scanning such as the screen-saver or the Simple User Interface):
Right click the 'a' blue icon, click Program Settings.
Go to Exclusions tab and click on Add button...
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
