Norton 2008 problem...
Status
Not open for further replies.
hfionn
......or so I think.I can access the other pc's from my Vista pc but I can only
access the public folder on the Vista pc from the XP machines.I have shared the C drive on the vista pc but when I try to access it I get told about not having permissions etc.Any ideas?
It probably is Norton. Remove it with the Norton removal tool. Replace it with either Avast, Avira(both are free) or NOD32(you gotta pay for this one)which is really the better of the 3. Then use Comodo fore a firewall. You should be able to access your shares normally then. It would not be the first time I've seen Norton cause this kind of problem.
Good luck.
    My Ever Changing Whim!
    Intel Core 2 Quad 9650
    Intel DQ35JO
    6GB Corsair DDR2 800
    ASUS 9800GT Ultimate
    19 inch Sceptre 19 inch Acer
    1 320GB Seagate SATA 1 250GB Western Digital SATA 1 200GB Maxtor SATA 2x160GB Western Digitals SATA 1 320GB Seagate External 1 120GB Western Digital External 1 80GB Westen Digital External 1 4GB Crucial Flash Drive for Ready Boost
    600watt Fortron Source
    Antec
    Fresh Air
    Razer Diamondback
    Microsoft Natural Ergonamic 4000
    My main rig runs Vista Ultimate or Server 2008. Depending on which Acronis image I decide to load.
Its not your Norton, you need to reset all your permissions, and sharing permissions, removing Norton won't help, it your Network setup.
I use Norton with my Network and it works perfecly well.
Joel is a fanatical anti Norton, he'll tell you to remove it, whether it helps or not.
Oh removing Norton will definitly help. It will free up resourses hogged by it in the first place.
Norton works for some. But the second it starts acting up your better off dropping it. Some people have misplaced values when it comes to symantec products. As soon as they bite them where the sun dont shine their song will change.
Good luck.
    Intel DQ35JO
    Antec
    Fresh Air
    Razer Diamondback
Good luck.
You see that proves that Joel is not up-to-date, the days of Norton hogging resources has passed, it has a very light footprint now,
But Joel wouldn't know that because he doesn't keep up-to-date sofware information.
I consider him a poor technician, who doesn't consider ALL the options, too hidebound.
No norton is still and always will be crap.
If the product was any good, then Jody Gibney senior product manager for Symantec/Norton Internet Security wouldn't have registered here, and under the disguise of a normal user and raved about how good the product was ;).
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Busted, Down on Bourbon Street,
Set up, like a bowling pin.
Knocked down, it get to wearing thin............
Thought a little Grateful Dead was appropriate music for z#'s last post lol.
I was wondering what position kitty held with Symantec..........
    Intel Core2Quad Q9450
    nForce 790i Ultra SLI(evga)
    8 GB DDR3 1333MHz
    2 e-GeForce 9800GX2(SLI mode)
    WD1500AHFD (Raptor 150 GB 10,000 RPM)
I only spotted this as Jody had an out of office reply set on her emails, so when somebody replyed to her post the out of office reply came in to my email.....busted
    Ryzen 9 5950X
    Creative
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
I have never had an issue with it, myself. I have been using Norton since the second edition of the program was put out back in 1996.
    Velocity Micro, HP Pavillion
    Intel 2 Quad Core Q9400, AMD Athlon 64 x2 4400+
    8 GBs DDR3, 4 GB DDR2 PC5300 (667 MHZ)
    nVIDIA GTS 250 (over clocked), nVIDIA 6150SE n430
    HP w1907
    440 Watts
    Velocity Micro
    Trackman Marble ++
    Logitech G15
    2 mbps
I'm afraid Norton is getting the boot.I've only tried it out this time as the first 2 months were free so its back to NOD.Never liked to old ones so I was willing to try the new this time but once a donkey always a donkey.
Sorry to hear that hfionn.
I removed Nrton IS 2K8 from a gonernment system today and then from another system I had to remove Norton antivirus 2008. Thats 2 systems that were returned to functional just by removing Norton.
All I can say is....
Hee Haw...Hee Haw!!
    Intel DQ35JO
    Antec
    Fresh Air
    Razer Diamondback
Hee Haw...Hee Haw!!
Sounds like the donkey as well. braying like a clown.:D
Thank god for Miracle ear.
    Intel DQ35JO
    Antec
    Fresh Air
    Razer Diamondback
How many more imaginary threads are you going to start, how much more tripe are you going to post, you're a sad little man caught out in your own fallacies, whose desperately trying to save face after being found out.:sick:
Enough
    Ryzen 9 5950X
    Creative
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Status
