system configuration modifications
nickoli tessla
while trying to load zone alarm antispyware I keep getting an error that says "you do not have access to make the required system modifications". "Please rerun from an administrators account". I have clicked on "run as administor" and compatibility settings but that install error keeps popping up. other programs install fine.
Nickoli:
Welcome to the Vista Forums :party:
Have you already installed zone alarm and are getting these errors or are you installing zone alarm and getting these errors?
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main 500 GB USB External 160 GB USB External 2TB USB External
    DSL 3MB
No , That message pops up right after I click on the zone alarm exe icon. It pops up and I cant get past the error message.
No, I cant get past the error message. It pops up right afer I click on the zone alarm exe file to install it
Hi Nickoli Tessla,
You will need to install this while logged on to a administrator account. It will not work from inside a Standard account.
If you are in an administrator account, then right click on the exe file and click Run as administrator to see if that will help.
Iam useing an administraor account it is the only account on this machine . I have tried right clicking and tried 'run as administrator' but the same error tells me to use an admin account,which I am useing. thanks
Ok, here is the latest. Iwent to the zone alarm forum site and followed the instructions. Remember Iam trying to install zone alarms spyware program. I already have zone alarm firewll installed. After I uninstalled the fire wall I tried to install the spyware program again and it worked this time! The error that was popping up was gone. Kool! But, as the program was installing a window popped up stateing that the zone spyware program has known driver compatability's with Vista! It said to check with CheckPoint for an updated version for Vista. Hummm? Well ya fixed the administrator problem! Thanks loads. But now I have another problem. I mean we! Thanks again.
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Nickoli,
What version of ZoneAlarm firewall are you using? Only version 7.1.248 is. Use the update feature in ZoneAlarm to update it. See:
ZoneAlarm by Check Point - Award winning PC Protection, Antivirus, Firewall, Anti-Spyware, Identity Protection, and much more.
AND
ZoneAlarm Software System Requirements
If it still does not work, then I would recommend to dump it and use the free COMODO Firewall Pro and Spybot Search & Destroy (anti-spyware) instead. It's what I use and I have not had any problems using them. You can download them from the link posted by Ted above.
Windows VistaSupported
Our most popular products, ZoneAlarm Internet Security Suite, ZoneAlarm Antivirus, ZoneAlarm Pro 7.1, and ZoneAlarm (free firewall), run on the Windows Vista operating system. Our newest addition to the ZoneAlarm family, the ZoneAlarm Secure Wireless Router, also works with Vista. ZoneAlarm Anti-Spyware is not currently available for Vista. Due to the different needs and functionality of the Vista operating system, some features and functionality on 2000/XP may differ on Vista
Thanks to all for the support. Brink ,this article is from the site that you sent. As it states the anti-spyware isnt supported in vista yet. It sure caused me some grief! Ill try your recommendations for the other programs. This is a great site! ,Nickoli Tessla
Well Nickoli, it was worth a try to see anyway. ;)
Hope you like the other ones.
