Norton Uninstall issue.. HELP PLEASE
Quasar3210
Hello all,
I am trying to get my Friends new Compaq laptop up and running. It came with a Norton Internet Security 60 day Free Trial. They currently have a subscription to Trend Micro Pc-cillin 2007 and want to add it to the new laptop.
I have tried Uninstalling it via add/remove programs. It says it was completely removed. I then tried to install Trend Micro, however when that runs we get an error message that says "a fatal windows error has occured please restart your computer and try again"
Then from searching thru this forum I found out about the Norton Removal tool. We downloaded and ran that and it found other things to remove. Once it was completed we tried to install Trend Micro again but still get the same error message.
At this time we are running a full system restore to bring the Laptop back to out of the box condition. Has anyone had this happen before, and are there any steps I am missing?
Thanks in advance for any suggestions.
Tom
yes it is a known issue with norton while trying to uninstall the norton anti virus utility you do tend to get this kind of errors . try this
1) Norton: http://service1.symantec.com/SUPPORT/tsgeninfo.nsf/docid/2005033108162039
hope it will work for you if it does help you dont forgoet to add to my reputation <<<<<<<<<
Thanks for replying, I actually had done that a couple days ago, as I said in my original post. I got it fixed, It was the user account controls causing the install error. Once I turned that off Trend Micro installed without an issue.
Down Load From GeekSqaud UNLOCKER
nlocker for Windows 2000, Windows XP and Windows 2003
Copyright (C) 2005-2006 Cedrick Collomb
ccollomb.free.fr
Using Unlocker
How often have you tried to delete or rename a file or folder and got
"Cannot delete xxx: It is being used by another person or program." ?
Unlocker is a tool which will help you removing this scandaleous Windows
bug.
Simply right click the file or folder and select Unlocker. If the file
or folder is locked then a window will appear with a list of processes
locking the file or folder. Select the locks and click Unlock and you
are done.
It is recommended to Unlock wisely and to close open processes locking
files or folder if any, but if only Explorer.exe is the culprit, do not
hesitate ! :D
Terms of Use
This software is provided "as is", without any guarantee made
as to its suitability or fitness for any particular use. It may
contain bugs, so use of this tool is at your own risk. We take
no responsibility for any damage that may unintentionally be caused
through its use.
You may not distribute Unlocker in any form without express written
permission of Cedrick Collomb.
Licensing
If you are interested in redistributing Unlocker, either in original
or modified form, or wish to use Unlocker source code in a product,
please send e-mail to [email protected] with details.
Reporting Problems
If you encounter problems, please visit UNLOCKER 1.8.6 BY CEDRICK 'NITCH' COLLOMB
and download the latest version to see if the issue has been resolved.
If not, please send a bug report to:
had this with parents pc, norton have a remove file works in safe mode
"Please be informed that the latest version of Norton Removal tool has been more improved and you can run it in Safe mode also, which will remove the Symantec folders and Symantec registry keys from your system."
They ended up keeping norton as it was simple to use, will get them on the eset security suite - installed it on 2 numpty friends's pc's one wiped it and put on avast, the other seems ok with it
    Self Build
    AMD Athlon 64 x2 Dual Core 6000+
    Asus M2A HDMI
    Geforce 8800 512Mb GDDR3
    On board 5.1
    Samsung SyncMaster 2232bw
    2 x 500GB Sata II Hard drives running in RAID 0 Freecom 500GB external USB
    Coolermaster 600Watt Quiet
    Coolermaster Elite Case
    default fans
    Razer Diamond back
    MS split keyboard
    http://www.speedtest.net/result/489957372.png
