I bought this new computer with Vista (expensive too!) and now I can't do the thing I love best with my computer. I play Sims 1 and I use PSP 7 to recolor and recreate objects and I have a program that transfers the objects from the Sims game to my PSP 7 program called Transmogrifier. The way it works is that when you are finished working on you iff object in PSP 7 you transfer it back to the Sims game via this Transmog program. The object is coming back to the Transmog but not appearing the game. There is a folder in the download section of the Sims game called "transmogrified" and the objects are supposed to go directly into it when I import the object. It's not happening.
The only thing I can figure is it must be the administrator/security issue that won't allow the Transmog to put a file into the Sims folder.
How can I get around it? The computer will collect dust if I can't contiinue with my hobby.
