soundmax ad1888 drivers?
lc_excalibur
Hello!
I have a lenovo 8382-cto, the sound chip is onborad, and in the lenovo web page there is no drivers for this sound card.
I found the realtek drivers and it play sound!.....but only on the speaker , not sound on the out connector.
Please help me....us!
Thanx from Spain
L.C.
I've got an Asus board with the SoundMax card and, unforunately, Asus support said that SoundMax has not provided them with a driver that works for Vista x64.
I'm only getting stereo with my 7.1.
^thats strange man.
Did u look into the Asus website to see if theres a driver there ?
Whats the model number of your Motherboard ?
    Intel
    Nvidia 9650M GT
    Asus N80VN-X1 Laptop
    1280 X 800
    1 X 250GB 5200 RPM
    11 MBPS
^thats strange man.
Yes, I've got the latest drivers.
It's a P5N32-E SLI.
I decided to break down and buy a Creative Audigy SE this weekend. Installed it and it works fine.
I've been in IT for over 15 years, so I'm not a rookie at this.
I try install, and update, and the driver not install on vista x64.
Thanx for all, i suppose that microsoft update or create drivers for this controller sometimes.
L.C.
If you're certain the driver is for the same Soundmax chipset you might try to edit the .inf file for the driver and add the specific PCI ID for your Soundmax. I've seen this trick to work on the internet though I don't have any specifics.
