Sound Blaster Audigy 2 problems in Vista 64
Squirtis
So i've done a search on the forums and it seems Vista sucks with all creative cards.
I have an Audigy 2 ZS and i can't get the sound to work for the life of me. The latest drivers are from May which seems almost unacceptable. I tried disabling my onboard sound card in the BIOS and in windows cuz i thought there might be conflicts but it didn't do anything.
So then i was thinking of getting a new X-Fi card because i thought it would have to work on Vista 64, and then i came across the other threads complaining about sound issues.
As of right now im using the Realtek onboard sound device...It is HD audio, but i would like my sound blaster to work properly. I'm still getting weird sound issues while playing Bioshock, once a lot of sounds start happening at the same time, some of them will just cut out.
Anyone know of any fixes for my Augidy 2?
im running
eVGA NF68 Nvidia nforce 680i sli
eVGA Nvidia 8800 GTS 640 MB
4 gigs of Crucial Balistix
Intel Core 2 Quad Q6600 G0 Stepping Kentsfield 2.40GHz
Sound Blaster Audigy 2 ZS
i am running an audigy 2 ZS in my computer with no problems at all. i let vista download the driver and install whatever one it found and it works fine for me
    intel core 2 quad Q9450
    gigabyte EP45-DQ6
    8gb Gskill PC6400
    Visiontek Radeon 4870x2 2GB
    X-FI fatality FPS 7.1
    Viewsonic VG2230wm
    1680X1050
    VelociRaptor WD1500HLFS 150GB 10000 RPM, WD CAVIAR black 750GB
    Antec TruePower New TP-750 watt
    Cooler Master HAF932
    XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
    comcast 16mb\second
Also using audigy 2 zs with no real problems. I don't have my eq and such but the sound works and I even have EAX via Alchemy.
Try removing everything drivers and card then run driver cleaner pro to remove stuff that was left over. Then try using the outdated drivers from creative's site.
I also wish we could get some updated drivers.
    Q6600 @3.1
    DFI UT X48 T2R
    Crucial Ballstix DDR2 800 4GB
    Asus HD4850
    Realtek HD onboard
    19" Hanns-G
    250GB Seagate
    BFG 1000w
    Thermaltake Armor
    Ninja B
I was on the creative labs site last night and noticed they are giving out the Vista software and driver cd for free on their site. I dont know if it will solve any problems since it hasn't arrived yet but ill let yas know ;)
The only problem i seem to have is i cant locate a way to mute my microphone so that i dont hear myself. this gets annoying. Other than that i dont have any x-fi problems but I dont use the card for anything other than music & gaming so no complex musician/midi/editing stuff tested by me.
http://us.creative.com/products/product.asp?category=209&subcategory=677&product=16743
Sorry guys, I guess i need more caffeine as I have replied with X-fi info in an Audigy thread . *slaps self.
I got same system specs as you, Vista Ult 64bit etc...
am use this driver
SBAXVSD_PCDRV_LB_2_12_0002.exe
works fine.
games i played it with.
TF2
HL2:EP2
Portal
GRAW
COD4 DEMO
SIM CITY 4
You also might want to check speaker cables...
pluged in properly, naked copper etc....
depending on the quality, I have a $30 shity speakers for my gf to use on other computer, and i hav to rotate the plug (while its pluged in fully), like trying to crack a safe open.
Once i found the right spot thou, and not move it, its fine.
