Greetings,
I am currently having somewhat of an annoying issue with this operating system. Before, I used to run Windows XP 64bit edtion, everything on there worked fine (including the 5.1 HD audio system I have). Now in this os, I only get sound out of 2 speakers (L + R). On top of that everything seems to be in lower volume, but, I'm assuming that's because there's only sound coming out of two speakers (I hope). I know it's not my hardware b/c it worked fine before in the previous os that I have mentioned, I also have a laptop that I used and it worked fine on that too, Vista is the only one giving me the problem.
I have the latest soundcard drivers installed from Auzentech's website and it's enabled to go Dolby Digital Live (DDL). I did disable onboard audio in the bios menu as well.
Here's what I have:
(Auzentech X-Meridian Soundcard: Optic cable to Panasonic XR-55 receiver)
(Speakers: Onix X-Series 5.1)
-Other info:
Intel C2Quad Q6600
Evga 680i Motherboard
Evga 8800GTS (640)
1x Raptor X150 HD
1x WD Storage 250G HD
620W Corsair Modular PSU
4GB of Patriot Extreme Memory
Is there a way to set up the devices in some type of menu? Or do I have to roll back to XP?
Here's what I have:
-Other info:
Intel C2Quad Q6600
Evga 8800GTS (640)
1x Raptor X150 HD
