garagetinkerer
Hi All!
Any and every help/advice is appreciated... I have an Asus K8-8VM mobo, and (yes it's) an Athlon 3000+ (K8 proc, i know i am to upgrade in a week or 2). The problem is that every time i restart after having installed audio drivers, the OS shows that no audio device is installed. I did some comprehensive googling about the same... however, i only found that i need to switch off my dsl router, if i must have audio on Vista. XP, it does fine for playback and all, it's only Vista which is causing me grief. My speaker system is a 4.1 setup, could that be an issue?
This happens on both Vista X64 or X86 (ultimate versions)
Thanks!
Thanks!
