Dolby Digital Live and Vista x64?
PsychoHamster
have a Intel D975XBX2 board and Dloby Digital Live works fine in Windows XP. Have gone for an upgrade to Vista x64 to use the 4GB of RAM but the option for Dolby Digital Live is either obscurely hidden or it does not exist.
Does anyone know if Dolby Digital Live is supported by Vista x64 using the Sigmatel 92xx? Anyone actually got it working?
Thanks,
PH
Ive heard it works
    Mobile DualCore Intel Core 2 Duo T7100, 1800 MHz (9 x 200)
    Sony VGN-FZ18L Intel Crestline-PM PM965
    1GB DDR2 SDRAM
    NVIDIA GeForce 8400M GT (64 MB)
    SigmaTel STAC9872AK @ Intel 82801HBM ICH8M - High Definition
    TOSHIBA MK1637GSX (160 GB, 5400 RPM, SATA-II)
    Alps Pointing-device for VAIO
    20MB Virgin Media
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
The onboard codec does support Dolby Digital Live, but only over a optical connection to speakers or external Dolby Decoder.
The only thing I use is Dolby Pro Logic II or Dolby Pro Logic IIx decoding, personally.
    Core 2 Duo E6600
    Intel 975XBX2
    8GB's of DDR2 800
    Radeon 3870X2
    HT Omega Claro
    Viewsonic VG2030wm Widescreen LCD
    1680X1050
    120GB 200GB 320GB
    ThermalTake Toughpower 700
    Antec P182
    four 120mm fans
    Microsoft Wireless Intellimous Explorer 2.0
    Microsoft Natural Multimedia Keyboard
    10MB
    16X LG DVDROM & LG Dual Layer DVD Burner Logitech X-540 speakers
