![usa](/images/flags/usa.gif)
![us_oklahoma](/images/region/us_oklahoma.gif)
![Note](/images/notesmall10.png)
Last Updated: February 17, 2020
HDA DRIVER VERSION: 6.0.8899.1
(Only 64-bit (x64) Windows)
Download at: Microsoft Update Catalog
Direct download links from Microsoft Update Catalog:
Download 6.0.8899.1 CAB for HDA "Windows 10 version 1903 and later Servicing Drivers" - 146.6 MB
For how to install: How to Install a CAB File in Windows 10
![Arrow :arrow: :arrow:](/images/smilies/arrow.png)
RELEASE DATE: July 26th 2017
DRIVER VERSION: R 2.82
Driver Version in Device Manager: 6.0.1.8186
Vista, Windows 7, Windows 8, Windows 8.1, and Windows 10
High Definition Audio Codecs: Driver Download Site
Update Add/Fix History:
- Customizations
- Bug Fix
![Tip](/images/tipsmall.png)
- You will need to have cookies enabled, check the accept box, click Next, and click on the High Definition Audio Codecs (Software) link before it will take you to the actual Realtek HD audio driver download page.
- You can download a ZIP version or the EXE version of the driver.
- When the driver installation is complete, you will need to set your audio settings again in the Realtek HD Audio Manager in the Control Panel (Classic View).
- Some OEM computers will have a custom version of the Realtek HD Audio Manager with the OEM manufacturer's name included instead. For example it may be named "Acer [Realtek] HD Audio Manager" instead for the OEM Acer.
- Operating System
- Windows 10 Pro 64-bit
- Custom
- Intel i7-8700K 5 GHz
- ASUS ROG Maximus XI Formula Z390
- 64 GB (4x16GB) G.SKILL TridentZ RGB DDR4 3600 MHz (F4-3600C18D-32GTZR)
- Graphics Card(s)
- ASUS ROG-STRIX-GTX1080TI-O11G-GAMING
- Integrated Digital Audio (S/PDIF)
- 2 x Samsung Odyssey G7 27"
- 2560x1440
- 1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
- PSU
- Seasonic Prime Titanium 850W
- Case
- Thermaltake Core P3
- Cooling
- Corsair Hydro H115i
- Logitech wireless K800
- Logitech MX Master 3
- 1 Gb/s Download and 35 Mb/s Upload
- Other Info
- Logitech Z625 speaker system,
Galaxy S23 Plus phone
- Operating System
- Windows 10 Pro
- HP Envy Y0F94AV
- i7-7500U @ 2.70 GHz
- 16 GB DDR4-2133
- NVIDIA GeForce 940MX
- Conexant ISST Audio
- 17.3" UHD IPS touch
- 3480 x 2160
- 512 GB M.2 SSD
