Vista sound driver for my Asus P5VD1-X mobo
Hi guys, I just want to ask help from you. I can't really find a Vista sound driver for my mobo. I have tried searching on Asus's website, but I can't find anything there. I would really appreciate if you could help me find the driver that I'm looking for. By the way, I'm using the 32bit version of Vista.
Asus are way,way behind and as yet do not have proper vista drivers.
I did and install the other day for a friend who had an asus mobo. Windows update installed drivers for the onboard sound.
I take it that you have no drivers and no working sound!!??^*
When you go into device manager is it flagged with a yellow exclamation mark?
If so, try doing a windows update to see if it will download the drivers for you!
Well, got 3 possible options.
1. If you have the unzipped driver files, not .exe, then you could manually
install them in Device manager.
2. If all you have is a .exe, then use compatibility mode. Right click .exe file
& click PROPERTIES. Under COMPATIBILTY tab choose XPsp2.
3. Do the Vista Updates & see if Vista can install a generic driver.
Onde eu encontro o Driver de som para a Placa mâe ASUS P5VD1-X, GeForce 5200LE, no VISTA ULTIMATE...... Estou sem som
English translation (I think)
Where can I find the sound drivers for my ASUS P5VD1-X, GeForce 5200LE, in Vista ULTIMATE...... I am without sound
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
