Realtek HD Audio Manager missing from Device Manager & Advanced Tab missing from BIOS
[h=1]I have a HP Pavilion dv6707us Entertainment Notebook PC. I was using Home Premium 32 bit Vista but I did a clean installation with Home Premium 64 Vista. I downloaded and installed all the drivers from HP’s site for 64 Vista. After clean installation I am facing the following problems.[/h][h=1]1. Realtek HD Audio Manager is missing from Device Manager.[/h][h=1]2. Advanced tab is missing from BIOS.[/h][h=1]3. CD/DVD drive is not reading media.[/h][h=1]Ø Installed the latest Realtek driver. Its showing in control panel. But not showing in device manager. When I checked in Device Manager sound, video and game controllers only conexant audio is there realtek is missing from there.[/h][h=1]Ø Now I am unable to use my external mic and internal mic volume is very low.[/h][h=1]Ø Looked into few forums there I found I need to enable my on board audio in BIOS but when I checked into my BIOS there is no ADVANCED TAB .[/h][h=1]My system details are :-[/h]Operating System : Windows Vista Home Premium SP 1 64bit
Ram : 2 GB RAM
Graphics : Nvidia GeForce Go 7150
System Model : MCP67
System Type : x64 Based PC
Processor : AMD Athlon 64 X2 TK-57 dual-core processor 1.90GH
BIOS Version : F.32
SMBIOS Version : 2.4
[h=1]Please please please help me…….[/h]
    AMD Athlon 64 X 2 Dual Core TK-57 Processor
    64-bit 1.9 GHz AMD Athlon 64 X2 TK-57 dual-core processor
    160 GB hard drive, 2 GB RAM
    Nvidia GeForce Go 7150 graphics
Re: Realtek HD Audio Manager missing from Device Manager & Advanced Tab missing from
I have the same OS and use Realtek. The only Realtek shown in Device Manager, Sound.... is the Realtek High Definition Audio. Are you sure you installed the 64 bit driver? The driver I have is 6.0.1.6873.
In Control Panel, DVD/CD-Rom drives, is your drive shown? Are there any problems noted?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Hi Mr Wither,
Thanks for your quick response.
Yes i have installed the 64 bit relatek driver.
But when i check in Device Manager\ Sounds there i am getting only Conexant Audio.
Realtek is missing from there. As i searched few other forums there they have given i need
to Enable On Board Audio from AUTO. When i checked in BIOS there is no ADVANCED TAB avbl there:(
Please please please help me i need my external mic to work.
If any other solution is avbl for fixing External mic i would love to love to go for that too.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Hi Wither,
Thanks for the reply.
I have installed latest conextant driver. And today i am gonna update from sp1 to sp2. Lets pray that may fix my problem.
Let us know how it turns out.
I think SP2 will help.
Also note that HP has an automated software which will search your system to determine the latest drivers.
I bought my wife a HP which has Win 7. It has the HP Assistant which can also help with these kinds of problems.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Did you ever get SP2 installed and did the conextant driver fix the original problem?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
