Windows Vista sound device missing
Smarty57
Hello, I've been looking around at forums for a couple hours total now, and couldn't find a solution to my problem.
When I mouse over the audio symbol in my task bar it says "No Audio Output Device is installed". When I go into device manager into the "Sound, video and game controllers" the only thing there is "Screaming Bee Audio". I tried to install a driver for my computer that were supposed to be for my card, but I installed it and it said no audio device could be found or something like that.
I have a Compaq Presario f750, but when I googled that I couldn't find my computers specs, it said it was like 64-bit (mines 32-bit) and it had more than 100 GB of hard drive space, and 2 GB ram.
Thanks ahead of time.
    Compaq Presario F750US
    AMD 1.9 GHz
    1 GB DDR2
In Control Panel, go to Sound. Is anything shown there and is it enabled, if there? Are you getting any sound out of your system?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
