No sound on Vista Home Premium (32 bit)
ali2013
I unplugged my sound cord and the USB cord from the motherboard recently. After putting the cords back, I have no sound. My sound worked before but now not.
I installed the driver again but in vain. My motherboard is ASUS P5KPL-CM, and my audio is VIA. On the audio manager, tit seems it is not detecting my cord on the back panel. However, it is detecting my speaker as default audio supply, the volume is 100, and when I play something, it does work, but no sound.
Help!
    HP Compaq Presario C700
    Intel Pentium Dual Core T2370
    HP 30D9
    2GB 677Mhz
    Mobile Intel 965 Express Chipset Family
    Conexant High Definition SmartAudio 221
    WDC WD1200BEVS-60UST0
Did you find your sound card in Device Manager?
    HP 30D9
    2GB 677Mhz
Try right clicking your sound icon on the bottom-right and selecting Playback Devices. Then play something on your computer and see if the indicator reacts.
    HP 30D9
    2GB 677Mhz
Sorry, I don't think I can help because I disabled my audio device in the process and cannot enable it now.
    HP 30D9
    2GB 677Mhz
Never mind, fixed now. Did you uninstall your driver when you reinstalled your driver?
    HP 30D9
    2GB 677Mhz
