No bootup sound
venom762
all of the sudden I lost the bootup sound, I found a replacement made sure its placed in the right spot all of the permissons are correct and file is named correctly. What am I doing wrong?
    Dell Inspiron 530
    Intel Core 2 quad Q6600 2.40GHz
    OFM586
    3.5GB DDR2 at 667MHz
    19inch dell HD flatscreen
    1280x768 60hz
    7mb
I also lost the ability to restore using the dell factory image. At boot I can access it by pressing F8, then it brings me to a screen where it shows a user other. Nothing I enter can access it.
    Dell Inspiron 530
    OFM586
    1280x768 60hz
    7mb
Hi Venom.
Its a little unclear what your talking about, by boot-up sound, do you have a little beep, or the 'welcome' type of music upon login.
What could you have done to remove it?
    HP Pavilion G6
    750GB HDD 6GB RAM
    AMD A6-3400M APU with Radeon HD Graphics
    25mbps
Nothing, I don't really use my PC much anymore. Its when you get to the windows logo screen there was so music that would chime. Now nothing. I did pull a Trojan off yesterday.
    Dell Inspiron 530
    OFM586
    1280x768 60hz
    7mb
Well, since you had a trojan there might be some leftovers that are trying to mess with your PC.
try downloading this.
Download | Spybot ©
    HP Pavilion G6
    750GB HDD 6GB RAM
    25mbps
Ill give it a shot and report back
    Dell Inspiron 530
    OFM586
    1280x768 60hz
    7mb
Just a spy cookie showed up.
    Dell Inspiron 530
    OFM586
    1280x768 60hz
    7mb
Hm, well perhaps a virus isn't the point at fault here.
Try going to your control panel and look for anything that has to do with start-up sound. Generally its in the Personalization section.
    HP Pavilion G6
    750GB HDD 6GB RAM
    25mbps
Yeah there is a setting for it, its checked to play.
    Dell Inspiron 530
    OFM586
    1280x768 60hz
    7mb
Is the startup sound the only issue you have with sound?
Try going to a start => run line, type in
sfc /scannow
and clicking OK.
Since sound seems OK except for the system ones the system file checker may be able to locate and replace a bad or missing file and get you back in business.
Otherwise, system start-up repair from your vista installation disk should fix this, but prepared to reinstall the updates since SP2
    HP Pavilion G6
    750GB HDD 6GB RAM
    25mbps
I ran the SFC already with no luck. And no disks other than drivers came with. I did fine in my recovery partition there is application that sets it back to factory specs. After I transfer all my pics to a different HD I'm going to try that. Its odd because I have used that before but I accessed it at boot by pressing F8. Now I can't get to that. It just sends me to a user page called other.
    Dell Inspiron 530
    OFM586
    1280x768 60hz
    7mb
Right click the speaker icon in notifications area, click sounds, click windows default, and click play windows startup sound. post back with results
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
That was the very first thing I tried.
    Dell Inspiron 530
    OFM586
    1280x768 60hz
    7mb
