help wmp is BuZZing
momocho
out of no where it starts buzzing when music is playing, it doesn't happen all the time but when it does it wont stop unless i close the program and restart it, just started doing it this year,,
    toshiba satelite A215
    amd turion64x2
    ATI Radeon
Hello, have you tried repositioning the speaker cables?
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
no cables, it's a lap top speakers are built in, I've had this puter for five years and this just started happening this year, I've tried up dating wmp, sound card drivers, used vlc player, windows media center, quicktime player, and when I tried these other media players, when the buzzing starts windows media player would show up in my mixer as if its running but it isn't, it didn't show up in the task manager applications tab, not sure about processes, I mute it in the mixer and it shuts it up but it also mutes the music even though I'm using a different media player to play the file??? file formats are mp3, wma lossless, wav, I don't think that really makes a difference, my fire wall is set to not let any program access the net, nor do i let anything update itself without my permition and I mannually update ussually once a day if any are availible, it sounds like an alarm clock buzzer I checked the mic too, it stays muted unless I need it for something, anyway I'm about positive it's windows media player causing it, but like how everything goes it's all just speculation until the fault is found...??? any thing you have I thank you
    amd turion64x2
    ATI Radeon
actually I didn't use quick time player, it wouldn't play all the formats,
    amd turion64x2
    ATI Radeon
You might run msconfig.exe and, in the Services tab, stop Windows Media Player and reboot.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
I am able to stop it, but I'm unable to prevent it, I don't know what's causing it, I will try that and going to check on another suspect, I'll report my findings if any
    amd turion64x2
    ATI Radeon
Do you have anybody in your neighborhood who does welding?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
wire welding? there are tons out there, does your neighborhood use any local classifieds, such as craigslist, kijiji, etc? if so, a quick search will help you out. unless you want to buy the welder/solderer for yourself. generally about $20 at a automotive store.
    HP Pavilion G6
    750GB HDD 6GB RAM
    AMD A6-3400M APU with Radeon HD Graphics
    25mbps
Hey Windows8- The reason I asked about the welding is that, if someone in the area does welding, there may be RF interference on his system. There could also be interference from other electrical sources.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Oh my bad, I thought you meant that some of his wires had been cut and needed to get welded back. :o
    HP Pavilion G6
    750GB HDD 6GB RAM
    25mbps
RF would have to be right close.
I think if you stop the windows mediaplayer network service, in msconfig services, it will go by bye
I suggested the latter a little while back and he said he was going to try it but, we haven't gotten any feedback.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
been busy I just got to disabling the network sharing services in msconfig will see if it works, other suspect not the problem i was thinking there were bogus copies of the music files being produced some how but not the case, i am on a ship at sea with all kinds of RF energy but this is new RF not the culprit, I'll let you know if disabling works
    amd turion64x2
    ATI Radeon
