NO Sound with Vista Home Premium
Sound not working
I am not a tech type.
Was using headphones with USB connection until dog ate them. There was no sound from computer speakers. Got new headphones with mic with regular plug for front of computer.
I go to sound: Device= Digital Output Device (HDMI); Applications= Windows Sound, CEC Main, Internet Explorer.
Sound => Playback = Digital Output Device (HDMI) Default
High Def Audio Device
Digital Output Device (SPDIF)
Sigma Tel High Def Audio CODEC
All show working properly.
Computer is Gateway Model: W6501.
What do I do next?
Steve
    Gateway Model 6501
Hello, open up your Audio Manager , then open up the Sound Manager , double check settings .
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
For me, i have a red icon in my task bar, do you have that ? If not, go to start button, in the search type Audio Manager , then see if it shows it in the results .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Try in search, hdmi audio
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Try restarting computer, then plug in those new headphones. see if it detects them and installs drivers .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Well, kinda hard to trouble shoot this without them. Let us know when they are with you. I have no idea what to do at this point.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Well, okay, but, i think we could get this sorted if we had them. But, if you do not come back, i wish you luck , it is probably a simple thing that needs sorted out.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
