Microphone on Vista Sounds Muffled
Rob141
I was just on Ventrilo Talking to people and skype also and they said that my microphone sounded muffled . SO i called the echo test service for skype and heard that it was . It sort of sounds like im in a tunnel and or have something blocking my mouth . Can anyone help me with this . It has only started this when i switched to windows vista 32 Bit I was on Xp before hand Please help me quick i need this resolved
  • Memory
    1x1x2 Gig DDr2
    Ati Amd Radeon x1300
    Seagate 2 TB HDD
    Razer naga 17 Button MMo Gaming Mouse
    Razer Lycosa Gaming keyboard
Hello Rob141 and welcome to the forums :party:
Try this:
Uninstall Driver
  1. Open the start menu
  2. In the search box, type Device Manager and open it
  3. Expand the Sound, video and games controllers category by clicking on the little + sign
  4. Right click on everything in there and select Uninstall
  5. Reboot your computer after that finishes
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Hi Tom . I was on the phone with Dell Technical support and I have gotten them to do all that remotely . I uninstalled all the drivers and anything that has to do with sound . They are still not working .. Im goin to try and install a couple of audio codecs and some other software that i have on my other hard drive to see if that works
Thanks Robert
  • Memory
    1x1x2 Gig DDr2
    Seagate 2 TB HDD
Hi Robert,
Okay, that's great. Let me know how it goes! I'll have a search around whilst you do that.
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Nope Still hasn't worked . Now the sound is completely shot .. All I can hear is static coming out not even muffled
  • Memory
    1x1x2 Gig DDr2
    Seagate 2 TB HDD
That's not very good :( What codecs did you install?
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Ive installed all the codecs and found out that it wasnt the codecs at all It is the microphone port on the back of the computer Just not gonna worry about it now going to build my own computer Thanks for the help tho
  • Memory
    1x1x2 Gig DDr2
    Seagate 2 TB HDD
Hi Rob
Okay, no worries. Hopefully that one won't have any problems!
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
