Vista Audio Recorder - Recovery the recorded file
thxbest
Hello,
When I was using the Vista Audio Recorder, there was a crash. The PC did not respond after recording and I couldn't save the audio file, so I had to restart the PC.
I still want to save the recorded audio file and I think I can find it in temp folder because the file is stored in temp folder or not ?? I'm not sure. How can I recovery that audio file? Where is it stored? What is the best thing to do?
Please help me!
Thank you guys
Hello,
Please help me!
Thank you guys
Hello, you say it was not saved, so, best bet is to start over, as there is nothing to recover for Recuva, which is a file recovery program and is free. Recuva - Undelete, Unerase, File and Disk Recovery - Free Download
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Thanks for the link. How can I know where the file is stored? I guess in temp folder but I'm not sure. Do you have experience with Vista Audio Recorder? Do you know where the file is stored when PC is crashed and you couldn't save the file?
http://www.piriform.com/recuva
