Power Outage/Speakers Out
VFN
After a power outage my speakers weren't working. I tested my speakers on another device and they were working. I then used system restore and my speakers are working again. Does anyone have an idea what happened? I should add that while my computer is protected with a power surge outlet my speakers are not.
Thanks.
    Vista Home Premium x64
    Dell Inspiron 546
    Sempron LE-1300
    2GB DDR SDRAM 800MHZ-2X1GB DIM M
    Integrated ATI Radeon HD3200
    VIA High Definition Audio
    Samsung 32" HDTV
    1366 x 768
    320GB NCQ Serial ATA (7200 RPM) w/ 16MB DataBurst Cache
It would be my guess a driver problem, which was corrected by System Restore. I can tell you this, System Restore only helps with software problems; the problem was not with the speaker.
A surge protector protects if the power comes on unexpectedly, or surges, it does nothing when power goes off (your need an Uninterrupted Power Supply (a surge protector, with battery back up) like I have. Your driver became corrupted and the Restore made it good again.
To check to see if other problems happened in the OS, read this tutorial
System Files - SFC Command
We had power out, too, in CT., from the Storm. New storm due about 9/11
