You should upgrade or use an
alternative browser .
Solved "slow speed" "natural speed" do not show
Dear all~
I am at this website.
Destroyer of Tyranny
First step: please post a link to the exact page of that website that you're on.
Dell Inspiron 1545
Intel Core 2 Duo T6400 @ 2.00 GHz
DELL - 27d90219 Phoenix ROM BIOS PLUS Version 1.10 A05
Generic PnP Monitor (DPMS), 15.3" (34cm x 19cm)
1366x768
Internal 320 GB
Portable 320 GB used for separate storage of media, plugged into USB port as needed.
Single built in fan
Touchpad, + Logitech wireless mouse (USB)
Built in
~150 kilobytes/sec DL
Usually have low HD free space left (<10 GB), often left on overnight. I really push its capabilities.
Ok it plays just fine for me. What browser are you using?
Dell Inspiron 1545
1366x768
Internal 320 GB
Single built in fan
Built in
Dear Slammer ~i appreciate your following up. i just tried again.
Haha well in my (and almost everyone else's) opinion here IE sucks. Anyway, try downloading another browser (I recommend Firefox, plus it's working on my Firefox) and see if the problem continues. I'd guess there's about a 50% chance it's just a bug in IE.
EDIT: I just tried to access that site using my IE and got the same problem. Try another browser, my friend
that's your problem. Something's wrong with IE. really nothing you can do about to fix it.
Again, I highly recommend you simply switch Firefox. After about a week (getting used to some of the differences) you'll wonder why you didn't sooner.
Dell Inspiron 1545
1366x768
Internal 320 GB
Single built in fan
Built in
Hello you might want to reset IE8 as I refuse to upgrade to IE9 as there are a lot of problems and there are a lot of people wanting to downgrade back to IE8.
Reset you IE heres how.
1. Open your browser.
2. Click Atl...
3. Click tools.
4. Click internet options...
5. Click advanced...
6. Click reset...
You will lose any ad ons that you have but the performance is great afterwards
a6530f Desktop
HP-PAVILION
M2N68-LA (Narra3)
LG W40 series widescreen
1600 X 900
300W
Mid-Size ATX
Microsoft Wireless Mouse 5000
HP Multimedia Keyboard
Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
Modem: 56K WinModem/
Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
Menory Card Reader: 15-in-1 Multimedia Card Reader
Media Drive
Dear Slammer ~
Worked. Thank you so much.
To AmericanCritic~
Thank you for chiming in.
Happy to help
I'm just glad it was such a simple fix!
Dell Inspiron 1545
1366x768
Internal 320 GB
Single built in fan
Built in
