Microphone making buzzing sound
cdown121
Just a couple of day ago I plugged my microphone in to my computer and it was working fine, now it just seems to make a consistent buzzing noise every time it is plugged in. I know it is not something with the headphones because when I am talking with someone on Skype I can't hear the noise. Is there any simple way to try and fix this problem, or could it be something to do with the sound card all together? Also, is there any mixer program that is better than the one that comes with vista? Preferably one that gives the option to lower certain frequencies, because I originally thought I could use something like that to try and reduce the buzzing noise. Thanks.
The buzzing noise is usually caused by a faulty cable on the mic, but if the noise can be heard through your headset while not using the mic then it could be just picking up white noise, try reducing the volume of your headset and see if the buzzing is still present, if so then you may need to try a different jack for your headset and/or microphone
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
I tried reducing the volume, but I can still hear it. The only problem with switching jacks is that the one making the noise is the only one that works for some reason. There is another in the back that will pick up the fact that the mic is plugged in, but nothing comes through even when I can see the levels going up and down.
