DwarfVader
Hello. It's a pleasure to browse your forums once again
I've always liked your support
Now to problem solving. Recently, after my desk's rearrangement, I've found out that my speaker channels are swapped, kind of. Like, the left channel is played by the right speaker, and vice-versa. I've tried browsing the web, the system sound setting, searching and re-installing drivers - nothing worked. However, I can't believe there's no program to perform such a simple task - swap audio channels.
The ones I've found on the web don't work, apparently ;p
Maybe you know a way? Thanks in advance
By the way, the reason why I reinstalled the SigmaTel High Definition Audio Driver was that I hoped that it's tray icon would reappear, as it once was there. A long time ago... But no, it didn't.
- Intel Core 2 Quad Q6600
- Intel DP35DP
- 2x 1Gb 800 MHz
- NVidia GeForce 9800GX2
- N/A
- DELL UltraSharp 2407WFP
- 1920x1200
- Samsung [Don't remember now] 1Tb Seagate [Don't remember now also] 250Gb
- Logitech G9
- Logitech G15 (Old version)
- 10 MBpS
