Volume mixer/Realtek HD audio manager
Kamo2x
On my Vista PC the old volume mixer has been replaced by the Realtek HD audio manager and I hate using it...... Does anyone know how to change it back?
    intel core i5 760
    MSI big bang fuzion
    6GB mushkin silverline
    2x XFX 9600 GSO
    quantom wave THX
You can use both programs, they work seamlessly with each other, it's just user preference, but you need the software running as the drivers need to be running for you to get sound, hope this helps
MrNeeds
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
Hello Kamo2x, welcome to the forum.
If you’ve installed or updated a new driver that is causing problems on your computer, you can easily roll back to the prior version of the driver with a few simple steps.
This link may help you to roll back to the prior version.
Roll Back to previous version Device Drivers in Windows Vista
Thanks,
Arvin
    HP dv2519tu pavillion Laptop
    1.50 GHz
    Winstron
    2.5 gig RAM
    intel onboard
    Conexant HD Smart Audio HD2
    HP Brightview Display
    1280X800
    SATA - 160 + 500 GB
    HP
    HP Laptop
    Air
    HP
    HP Laptop
    4 MB/SEC-Download, 2 MB/SEC-Upload
