I have windows vista home premium 64 bit and have lost the volume icon in the system icon tray. I have tried the notification Area - Sytem Icons tutorial, method 4. In step 4 I click HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
All I have in the right hand pane is: (Default) REG_SZ value not set. Can comeone help me out. Thanks
1 x 640Gb (SATA 300)
1 x 1Tb (SATA 600)
Stock PSU - 375W
Dell XPS 420
Stock Fan
Dell Bluetooth
120 kb/s
Thanks for the response. I did as you instructed, when I restarted I have no icon. I went to the regedit and in the right pane I have:
HideSCAVolume REG_DWORD 0x00000000 (0). Any suggestions
ViewSonic VA1912w Widescreen
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
1 x 1Tb (SATA 600)
Stock PSU - 375W
Dell XPS 420
Stock Fan
Dell Bluetooth
120 kb/s
I deleted HideSCAVolume REG_DWORD 0x00000000 (0) in the registry and restsrted the computer and still have no volume icon, I do have a network icon and a clock.
1 x 1Tb (SATA 600)
Stock PSU - 375W
Dell XPS 420
Stock Fan
Dell Bluetooth
120 kb/s
I went back and did the following steps:
Went to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer
I right clicked on HideSCAVolume REG_DWORD 0x00000000 (0) and clicked delete then yes. I then restarted my computer, still no volume icon. Went back to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer
HideSCAVolume REG_DWORD 0x00000000 (0) was gone. Am I doing something wrong?
Ed
OK. Try setting the values to 1 as though you want to hide the icon and then restart. Now delete the values as per the Tutorial. Sometimes, for unknown reasons, you need to toggle the values in order for your desired effect to stick.
I have my icon back. I right clicked on the tray and properties,notification area and checked volume. I tried this before but it would not let me ckeck this box.
Thank you for all the help I appreciate it.
1 x 1Tb (SATA 600)
Stock PSU - 375W
Dell XPS 420
Stock Fan
Dell Bluetooth
120 kb/s
