Hey, I've tried repairing speakers, checking for updates, switching which speakers I use, loads and loads of forums, but I can't get sound coming from the speakers, even though in the tests, they say they're fine. All my speakers/playback devices are showing, working or not, but I can't fix the problem.
I recently had to do a system restore, because of internet problems, took me ages to sort out, however the sound wasn't working before the restore anyway.
Haven't tried uninstalling/reinstalling the sound card/device yet, mainly because I only have my laptop here, if i need any disks then I'll need to wait a while to get them.
Sound does work with external speakers plugged in, so I'm starting to think I might need to get my laptop speakers fixed?
Sony Viao AR-71M is the model, I believe.
Any suggestions would be much appreciated
Thanks
Matt
Thanks
Matt
