No Sound, Can't access Device Manager
Campheel
I can't get any sound from laptop. However in trying to follow suggested fixes, I can't access my Device Manager. I get the following message: C:\WINDOWS\system32\mmcbase.DLL either not designed to run on windows or it contains an error.
System Specs:
Dell Inspiron 1525
Vista Home Premium
Service Pack 2
32-Bit
Intel Premium Dual Core CPU T2370 @1.73 GHz
RAM 2GB
Any help???
    Dell Dimension E521
    AMD Athlon 64 X2 Dual Core Processor 3800+ 2GHz
    2GB Dual Channel DDR2 SDRAM at 533MHz- 2DIMMs
    256MB NVIDIA Geforce 7300LE TurboCache
    Integrated 7.1 Channel Audio
    Optiquest 19" widescreen lcd
    1280 x 768
    250GB Serial ATA Hard Drive (7200RPM) w/DataBurst Cache™
    Tower
    Dell USB Keyboard and Dell 2-button Scroll Mouse
    DSL 3.0 Mbps down 384 Kbps up
Hello Campheel and welcome to the forums :party:
Can you do this for me please:
SFC Scan:
1. Open the start menu
2. In the search box, type cmd
3. Right click on command prompt and select Run as administrator
4. In command prompt, type:
sfc /scannow
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
It won't complete scan. Verification process gets to 90% complete. Then freezes. Had to do a hard reboot. Did so in safe mode...tried again...froze again at the same point.
    Dell Dimension E521
    1280 x 768
    Tower
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
