Sound stuttering on all applications
selector
Hi - I'm new here, but what a great forum.
Heres hoping someone can help........
I have a Toshiba laptop with vista and the sound has finally given up. Its always been a bit clicky, but recently its got to the point where I can't listen to the media centre or use the i-player or youtube etc. It just stutters and seems to run slow. At first I thought it was my internet connection but now the media player does it, I'm thinking its the laptop. Its also doing the stutter when I just click on enter or back.
I have read on google that it may be the drivers for the realtek audio, but when I go to 'update driver' it says windows has detected the most up to date driver is installed.
If I need a new driver where do I get it ? and how do I install it ? I'm a real novice at all this !!
Please help.......
Realtek
Download to your computer then go to device manager and update the driver again, but tell it to search your computer, it will ask you where point it to the downloaded file.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
I looked in your system specs but there is not enough information about your computer for me to say. Go to start type device manager go to sound expand and see what you have its where you will be going to update the driver as well
    LENOVO 64734VM
    15 inch
Right hand side of the page I sent you to Quick links,HD Audio Codec Driver.
    LENOVO 64734VM
    15 inch
Thanks for all that - I've downloaded, uninstalled, rebooted and installed. The sound on you-tube and my media player is exactly the same :mad:. However when I click enter/return its not stuttering anymore so one thing is better !
Is there another driver that might be causing this - something to do with the media player maybe - I'm clutching at straws, I have no idea what I'm talking about really !
Any help greatfully recieved - thanks
sounds like the movie is buffering,is your connection slow? If it is pause the video and play it when the file has finished loading
Does it happen to videos you already have on your computer?
    LENOVO 64734VM
    15 inch
    home brews
    pc1 msi k7delta, pc2 asus kn79txd evo
    pc1 2gb crucial, pc2 4gb gskill ripjaws
    pc1 bfg 7800gs, pc2 shapphire 5770 vapor-x
    onboard
    corsair hx
    jeantech phong
    pc1, handmade waterblocks,passive cooling, pc2 corsair h50
    logictech mx510s wired
Try Start, All Programs, Accessories,Command Prompt, Right click and run as Administrator,Type sfc /scannow
This will check windows file system (note the space before/)
    LENOVO 64734VM
    15 inch
    LENOVO 64734VM
    15 inch
