So yeah, I know that Acer displays the Realtek HD Audio Manager as ACER's.
I have no problems with the name being different. The problem is, after 4 successive times of uninstalling the driver and installing the new one, the HD Audio Manager does not update. Its stuck at one version. So can anyone help me update the HD Audio Manager? My dumb guess is that Acer is not updating the HD Audio Manager as it'll be changed to Realtek.. I have tried downloading and installing the Driver from Acer's website but its still the same.. Help is much appreciated.
Welcome to the Vista Forums zafz,
....and before I go any further I recommend that you forget all about Acer to source your driver updates - they are notoriously slow at getting up-to-date with the latest from Realtek.
I suggest that you go straight to the Sound & Audio Forum Sticky Note at the top of the page
here , and always update from there.
But first of all, make sure that you
read the notes that Brink has written to the heading of the post at
Latest Realtek HD Audio Driver Version, and because you also have an Acer, have a
good read of the Posts from #430 [My post]
right through to #446 [Brinks Post]. This will give you some idea of what I went through when updating my Audio driver, and how it all worked out. At the moment you find yourself in a situation much as I was at that time.
Pay particular heed to the advice to save the Installation File to your desktop, and also the need to download and run the file twice -rebooting after each run. Anyway, if you read through those posts carefully, you shouldn't have too many problems in successfully installing the latest version.
You will also see that I brought Brinks attention to the fact that with Acer systems, you will find your Audio driver details and settings under
Start>Control Panel>Acer HD Audio Manager, and he added a note to that effect to the start of the Forum.Then if you want to keep up-to-date with the latest releases, Click on to
Thread Tools in the heading bar at the top of the first page of the Forum, then select
Subscribe to this Thread from the drop-down menu, then each time there is a post advising of the latest version available, you will get an email telling you of that fact.
Hope this is of some help to you, and that all goes well......Come back and let us know how you get on.
