No sound after hard shutdown
  • Thread starter Thread starter s660117
  • Start date Start date
S
s660117
I am running Vista 64bit Home Premium on a Dell Inspiron. I have a Creative Audigy SE sound card installed. The sound was fine until we experienced a loss of electricity this afternoon which resulted in a hard shutdown, after which I had none. I have tried updating the driver (using the driver I already had installed), uninstalling and re-installing the device, and re-seating the card, but without success. If I click on speakers in Control Panel/Sound and play a song, the volume bar acts as if music is playing.
Should I replace the sound card, or do I have a software problem (registry, perhaps) caused by the shutdown.
Thanks in advance,
s660117
to help eliminate a software or hardware problem do you have onboard sound card to switch on?. have you tried using system restore back on a date when it was working?
just in case of damaged files, try runing "dxdiag.exe", "sfc.exe /scannow"
it may be worth trying a proper reinstall, remove the hardware from device manager, remove the software and then takeout the card and rebooting. then use a driver cleaner such as this for eg Download Driver Cleaner Pro v1.5 (freeware) to remove old files and profiles then reboot once. shutdown and reinstall the card.
    home brews
    pc1 msi k7delta, pc2 asus kn79txd evo
    pc1 2gb crucial, pc2 4gb gskill ripjaws
    pc1 bfg 7800gs, pc2 shapphire 5770 vapor-x
    onboard
    corsair hx
    jeantech phong
    pc1, handmade waterblocks,passive cooling, pc2 corsair h50
    logictech mx510s wired
